Wires goiing into floor pan in trunk - where to?
Stripped my interior, had a cage put in, about to paint. I'd like to remove the harness so I can get a better paint job, but I'm not sure where all of that stuff goes. I am guessing the one on the passenger side goes to the fuel pump (which I can access pretty easily). But I have no idea on the driver's side? Does that go to the pad wear sensors? I've removed those from my car, so I can just cut if that's the case. Anyone know for sure?
Should have specified the front part of the trunk - right before the rear seat. What Samluke said makes perfect sense - the speedo sensor is in that area, and the LR brake caliper is, as well. I think hte other side replaces the speedo sending wire with fuel level and pump wiring (and keeps pad sensor).
Gadzooks, anyone know of a way to remove the sender harness without either cutting it or dropping the tank? I've loosened the strap, which dropped it a little, but it appears to be positively retained somewhere I can neither see nor feel. I'd rather not cut the wires, if I can avoid it.
