how does this wheel size sound for my car
87 951
found a set of boxster wheels I think they are from a "S"
Rim = 17x7.5 offset 52mm
Rim = 17x9 offset 47mm
any probs fitting my car?
I have the same wheel sizes/offset that you listed on my 89 951. I don't know how they will match to an 87 but they are fine on an 89 with stock ride height.
What size tires are you going to put on? My old tires are...
F -- 215/45/17
R -- 255/40/17
I'm looking to get some new rubber and would like to put on these...
F -- 225/40/17
R -- 275/40/17
Has anybody fit a 275/40 on a 9 inch rim? Street use only.
F -- 215/45/17
R -- 255/40/17
F -- 225/40/17
R -- 275/40/17
F -- 215/45/17
R -- 255/40/17
F -- 225/40/17
R -- 275/40/17
F -- 215/45/17
R -- 255/40/17
F -- 225/40/17
R -- 275/40/17
thanks teddy question a 17x10 rear wheel whats ofset is safe to fit? i may have some of these wheels someone wants to sell me
he is going to look into the ofset i think 65ish is ok?
I'd agree. For the rears, the 245/40/17 will get you to about the same overall diameter and section width as the stock (88 and above I think) 245/45/16. The 255/40/17 will get you a bit more rubber on the road, but you'll be increasing your sidewall height and overall diameter.
Great site for comparing tire sizes:
http://www.1010tires.com/tiresizecalculator.asp
I'll try to snap a few later today. I've had zero issues running this setup, but if I had it to do over again, I'd probably go with the 245 or 255s. They are usually a much cheaper tire.
