Electronic Boost controller... who is using them??
Old 04-06-2011, 01:30 PM
CDH-CTT
CDH-CTT's Avatar
jasonlp,
Thanks man!!!!
Im still running a single port wastegate....will that make it different??
Old 04-06-2011, 01:31 PM
jasonlp
jasonlp's Avatar
Originally Posted by CDH-CTT
jasonlp,
Thanks man!!!!
As far as I know you can run it fine in single port. Dual port is used more for higher boost applications 20psi+ I believe
Old 04-06-2011, 01:33 PM
JustinL
JustinL's Avatar
I use Megasquirt II to control my boost. Works great.
jasonlp
jasonlp's Avatar
Old 04-06-2011, 01:35 PM
jasonlp
jasonlp's Avatar
I use a vi-pec to control mine closed loop with none of the fuzzy logic 1-3 kPa variance less then half a PSI!
Old 04-07-2011, 06:19 PM
CDH-CTT
CDH-CTT's Avatar
so I got it all connected together but I'm taking the vac/boost signal from the FPR instead of the KLR boost line..... should I move it to the KLR boost line instead??? Right now it works but it seems like I will have to dump a TON of time into tuning it....
Old 02-08-2014, 07:17 PM
mc05duck
mc05duck's Avatar
http://www.aemelectronics.com/tru-bo...ller-gauge-757
Anyone know about the reputation of this electronic boost controller? I'm only going to run 15.5psi boost on a k26-6 Turbo with a Vitesse Chip.
Also, do you have to do a Venturi Delete hose job with any kind of electronic boost controller?
Thanks!!!
Old 02-09-2014, 12:34 AM
gpr8er
gpr8er's Avatar
Originally Posted by Rob
I had my AVCR mounted inside the center console. I loved the AVCR. It gave consistent boost all the time once it was setup.
cool mounting solution. I had the Apexi but sold it. I found the control panel just too large and too confusing setup for my small mind....
Old 02-09-2014, 09:24 AM
dmcampbell
dmcampbell's Avatar
TurboSmart eBoost2 with a Lindsey DPWG. No complaints and very simple to use. Mike
Old 02-09-2014, 11:07 AM
944Phil
944Phil's Avatar
I'm using the Apexi controller ( Jason's old one) works great. Haven't had the car running long enough to actually dial in all the settings.
I hid in in the center console because it contrasts with the interior.
Old 02-09-2014, 06:56 PM
mwc951
mwc951's Avatar
I love the Blitz SBC-iD
The dual solenoid in dual port mode ROCKS!
INSTANT boost!
Quick Reply: Electronic Boost controller... who is using them??
