MAF Question/Observation
Why is there such a huge price difference between MAF kits? A friend of mine has a Merkur XR4ti with a Modern Performance MAF kit (along with some other mods). He paid in the neighborhood of $500 for his kit. Why are kits for 951s in the $1100 to $2000 range? I think MP makes a kit for the 951 but I am not sure of the price, quality or performance. Judging from the performance of the Merkur, I would say it can't be too bad. I know you get what you pay for sometimes, but something doesn't compute. I guess if you wanted to be resourceful you could put your own kit together and save a few bucks.
Justin
Justin
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
Call them up and talk to Nick.. They make replacements for all "bosch" type air flow meters. It is good stuff i am told.
$575 includes the sensor, filter, bolts.
Everything you need to connect it to your J-hose. I am hoping to replace the J and have it sit in the fender well though.
It has WoT and idle adjustments on it.(same as lindsey's as far as i can tell)
It is not true to say that with only 2 adjustments "the fuel curve will be linear"
YOur chips take care of the rest.
sounds like it will do just fine for me.
I am hoping to be able to put around 310 to the ground with this unit and a turbo upgrade.
Any hp gain would be pretty much from cranking up the boost. There is a huge argument over this stuff
-I beleive you will gain about 15 hp @ the same boost level though. FRom what i have seen.
I plan on buy a really conker of a turbo though so i can make the numbers i want to at low boost pressure.
