I have bin trying to track down an oil leak without much luck.The engine oil leaks on to the crossover pipe only when the motor runs. First I'll let you know what i have changed. Pan gasket,rear seal and balance shaft o rings.What other seal/gaskets/o rings are in the back of the motor that i should consider changing.This leak is driving me nuts.
