Idle Vacuum pressure question
Old 03-24-2011, 09:28 AM
JohnKoaWood
JohnKoaWood's Avatar
Originally Posted by ehall
That's what I'm thinking. I'm thinking that I'm a tad retarded.
Fixed it for ya!
Old 03-24-2011, 09:29 AM
Bri Bro
Bri Bro's Avatar
That is a good point, if you are off one tooth on the cam belt, it will run but will be down on power.
Old 03-24-2011, 11:00 AM
minho78
minho78's Avatar
Fully warmed I get 18 idle 22 to 24 off throttle.
Old 03-24-2011, 11:43 AM
ehall
ehall's Avatar
Originally Posted by JohnKoaWood
Fixed it for ya!
Look Guys! Corky learned to use a keybaord at his "special" school!
Old 03-24-2011, 11:44 AM
ehall
ehall's Avatar
Then the question is am I off just one tooth or two?
Old 03-24-2011, 11:51 AM
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
Originally Posted by ModdedEverything951S
I pull about 19 at idle, and around 24-25 in/hg when decelerating.
Actually you are making about 21” at idle and almost 27” on deceleration. The Mechanical gauge does not understand that you are at a higher altitude – but the MAP sensor knows!
Quick Reply: Idle Vacuum pressure question
