Name that problem(Video)
Old 03-22-2011, 11:47 AM
slap929
slap929's Avatar
Default Name that problem(Video)
Cam tower not working? My guess is the lifters. What say you?
http://www.youtube.com/watch?v=AJagK...eature=related
Old 03-22-2011, 11:53 AM
minho78
minho78's Avatar
It looks like there's oil starvation.
Old 03-22-2011, 11:57 AM
Tedro951
Tedro951's Avatar
Sounds just like mine did. This racket went on for a while(maybe 30 mins, then went away). Hasn't come back.
Notice how it sounds better with some RPM? I just did more of that....
Old 03-22-2011, 12:01 PM
Ronin-951
Ronin-951's Avatar
Oil, or more precisely, lack thereof.
Old 03-22-2011, 12:30 PM
Andral951_S
Andral951_S's Avatar
was the car not in use for a while !
Old 03-22-2011, 02:00 PM
slap929
slap929's Avatar
This isnt a video of my car, although it does sound similar. I am slightly worried with the sounds it makes, but yes the cam tower was taken off(and left off for some time) and now it sounds like this.
Old 03-22-2011, 02:15 PM
Rock
Lazer Beam Shooter
Rock's Avatar
If the cam tower was taken off and left for some time, then you need to give it some time running before those lifters can pump up.
They are hydraulic so the need oil. Crank her up and then let it run for a bit and see if the problem goes away. It's not going to blow your car up, but make sure that the car has oil and there is oil pressure first.
Old 03-22-2011, 02:29 PM
doabarrelroll
doabarrelroll's Avatar
+1 on lack of oil. Have a good look at your oiling system and make sure it is running properly.
Old 03-22-2011, 05:39 PM
hevquip
hevquip's Avatar
Did they put a tractor engine in it? That sounds like the problem...
Old 03-23-2011, 08:55 AM
Tedro951
Tedro951's Avatar
hevquip nailed it! Its got the cummins conversion. Gets 40MPG highway!
Old 03-24-2011, 06:54 AM
max_boost951
max_boost951's Avatar
I use to put lifters in chevy trucks. Even when you presoak them in oil and install them, they still sound like you left a wrench in the cylinder for about 20 min. How long has the car ran like that?
Old 03-24-2011, 07:37 AM
Paulyy
Professional Hoon
Paulyy's Avatar
Our cars don't run on diesel....
Id check how much oil you've got and it's probably old and real thin.
Old 03-24-2011, 11:50 AM
Tedro951
Tedro951's Avatar
This may be a victim of the Victor foul up. See Mikes thread....
Old 03-24-2011, 01:06 PM
951Saga
951Saga's Avatar
Oh this thread...ALERT "Paper Cam Housing Gasket" from Lindsey Racing.
Old 03-24-2011, 01:24 PM
Paulyy
Professional Hoon
Paulyy's Avatar
I was thinking the same thing after i seen that thread.
Quick Reply: Name that problem(Video)
