calling john from vitesse
my pc guy says that it says connected and downloading then in middle of download it says no connection then goes back to downloading then its says again no connection then stops downloading.....so he tries another port, tells system to change to port 3 instead of port 4 and then the same thing happens...starts download then says no connection again.
i will try another com/usb cable and driver on same pc then try on a different pc.
reason why the fuel pressure is so high is when you turn it down to say 45psi from the 50psi its set at....it goes lean(12.2 WOT)...so until i can tune it..it has to stay at around 50.
again i thank you guys for the help!
adam
adam
Still sounds like a hardware connection issue.
Is the SMT-6 a serial connection only? (Hence the need for a USB->Serial converter?)
As I understand it, serial connections operate on very strict, rigid timing. If the timing gets out of sequence, you will lose your connection. USB is not fixed timing, and some devices run into issues when using a USB to Serial converter. People have had similar issues to yours when using the serial version of the VAG-COM cable on VW/Audi products with a USB converter.
adam
adam
It sounds that you have a USB-to-COM issue(s). Not all USB-to-COM are the same, the one I use and it works great for me is from EasySync-ltd.com
GOT IT WORKING....IT WAS THE USB DRIVER!!
YOU GUYS ARE AWSOME
NOW I NEED THE MECHANIC TO HOOK UP THE REST OF THE WIRES SO I CAN DATA LOG....BUT I DONT THINK I HAVE ALL THE WIRING DIAGRAM/INSTRUCTIONS...I THINK THAT WAS WHY HE DIDNT HOOK THEM UP IN THE FIRST PLACE
I READ ALL THE DOCUMENTS I GOT WITH THE SYSTEM AND I DONT THINK I HAVE ALL THE INSTRUCTIONS FOR WIRING THE FUEL CONTROLLER.
ANY HELP IS APPRECIATED
ADAM
YOU GUYS ARE AWSOME
ADAM
Why can't the SMT-6 and other similar products be made with a USB port in the first place? This is 2011... I continue to have connection issues. I have to open the software, connect the cable and let it sit for a few minutes before I attempt to connect. If not, I get the "no com" error. Now that I know the process, I can deal with it.
The new VR-8x PB is USB based...
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The better solution is to get a PC Card serial interface – these work much better and almost all Laptops have some sort of PC card interface.
BTW – nice customer support John! Not many vendors will help out folks that have 2nd hand equipment!
No problem helping out. And make that 3rd hand .
again thanks for all the help guys!!
so after reading the instructions....i see the rest of the wiring diagram is in the software....will axcess it today and wire the rest for data logging.
when it cuts out in fourth gear @ 15psi....is that the system cutting out for timing/detination...or im thinking it might be the wastegate seal letting go??its a turbonetics newgen wastegate and it has a rubber seal at the top when you install the spring...i will try tightening that today too.
also the electrical gremlins came out yesterday....overheating now and then...like the radiator fan isnt coming on and my temp gauge and fuel gauge start to flutter when its overheating....then a few minutes later its fine!!
is there a certain fuse or circuit that controls these gauges and or cooling fan??
maybe i should just start another thread with all these glitches/problems!?
again...thanks to everyone that has helped me out.
adam
adam
