manifold instalation question
I was wondering if its possible to reinstall the exhaust manifold on a 86 951 through the top, it was removed to be rewelded and I would like to find out before I go ahead and get it welded. I removed both pieces since the 1-4 couldnt be removed alone..Thanks...
Sure you can! Much easier to remove with the head. If you pull a stud or two from the head, you should be able to install the headers easily. I've seen people wedge and pry them in with crowbars, 2x4s, golf-clubs, etc. I suspect this is where a lot of the cracking comes from... <img border="0" title="" alt="[Frown]" src="frown.gif" />
You can install the headers with everything in place. When you go to install, you'll find that there's a stud or two that gets in the way. Clamp some small vise-grips on the smooth part of those studs and remove them. The headers will then drop into place. Re-install studs and tighten everything down.
