RFPR+sensor advice
You can use that one but it will have to be a custom install, your going to need new fuel lines and I think metric fittings.
A 3bar adjustable FPR from Lindsey among others will do the same thing and it's plug and play.
http://www.lindseyracing.com/LR/Parts/944FUELREG.html
Or if you insist on doing it the hard way, you can find everything you need here:
http://www.extrudabody.com/servlet/t...cts/Categories
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
I will be using one off the end of the fuel rail with a gauge and a brass tap for a sending unit.
You can get stainless steel lines at Jeg's and Summit Racing among others or here http://www.classictube.com/
Ohh pressure sensor = Fuel pressure sending unit!![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
http://www.egauges.com/vdo_send.asp?..._Fuel_Pressure
This looks to be the same thing for a little less.
Don't forget these guys, I have the display and discovered that they have the fuel "sensor" thjat plugs into the ZT2 and display after I bought a standalone FP Gauge!
http://www.zeitronix.com/installatio...allation.shtml
