Your other (hole) picture your EGT looks ok, I lined mine up with the crossover pipe just to make sure it stayed clear of the WG, but the orientation you have should be fine!
Where do You get one of those? Does it come with a gauge?
PM Laust Pedersen, no gauge, but is plug and play to Zietronix, and will work with other gauges / data suites as it is a K type... only one I know of that plugs right into the factory emissions test port though!
