where to buy intercooler pipes
Old 06-18-2002, 03:52 AM
TurboTim
TurboTim's Avatar
Post
The aluminum cost more then the stainless because of the amount of work it takes prior to welding. Aluminum must be very clean to weld it appropriately.
Tecart,
We changed our pipes since you got your set.We started to cut grooves into the pipes to prevent them from blowing off when you get on the boost hard. We also use a different type of hose then the Purocil we used to use. We are always trying to make our products better;^)
Old 06-18-2002, 09:48 AM
Konstantin
Konstantin's Avatar
Post
[quote]Originally posted by perry951:
<strong>
Seriously!</strong><hr></blockquote>
Yes but the $400 are for 3 pieces including a J pipe that goes from the K&N filter to the Turbo.
The 1 Piece turbo J pipe only cost $120.00
Konstantin
PS I am not sure if hoses etc are included but I have here tons of hoses and clamps teh same taht Porsche use in their Le Mans GT1 so It is good enough for me.
Thicker than Purocil and with 3-5 layers in the hose. Thicker than purocil and much more stronger
Old 06-18-2002, 12:30 PM
Perry 951
Perry 951's Avatar
Post
Well, if he is including the MAF inlet, that is better. He did not make that when I ordered mine, so all I got was the pipes.
Still... they are beautiful.
Old 06-18-2002, 02:07 PM
Bri Bro
Bri Bro's Avatar
Post
In an attempt to get the facts correct, he is a reply I received to an Email I sent yesterday.
Brian, here is the current price list if you would like for reference or to share with any interested parties.
1) 3 piece turbo pipe kit: $400.00 polished
2) 3 piece turbo pipe kit: $330.00 Brushed finish
3) 2 piece IC kit: $280.00 polished
4) 2 piece IC kit: $230.00 Brushed finish
5) 1 Piece turbo J pipe: $150.00 polished
6) 1 Piece turbo J pipe: $120.00 Brushed finish
Old 06-18-2002, 03:15 PM
Luke
Luke's Avatar
Post
Perry,
Have you ran your car with these pipes Yet? I have been having some issues but am not sure what is at fault ??
Old 06-18-2002, 03:21 PM
Sloth
Sloth's Avatar
Post
What is the advantage to upgrading the intercooler pipes. Does the turbo spool faster? Will it help get more power?
My mach tells me that the stock pipes will flow up to 500hp and is not worth swapping unless you are upgrading the intercooler.
<img src="confused.gif" border="0">
Old 06-18-2002, 05:07 PM
Perry 951
Perry 951's Avatar
Post
[quote] Perry,
Have you ran your car with these pipes Yet? I have been having some issues but am not sure what is at fault ?? <hr></blockquote>
Naw.. not yet. I am finishing a deal for a new block (a hell of a deal I might add), then I need to put that together. Oh.. and the car is still in peices.
You should have less lag, and since I am flowing a hella lot more air than the stock K26, I should benefit fine. I don't think this is a wise upgrade if the rest of the car is stock. Perhaps Tim has some info on gains on a stock 951.
Old 06-18-2002, 06:49 PM
Luke
Luke's Avatar
Post
one of my stock pipes had a hole the size of a quarter in it, so I said "why not" ........
Im having some issues with mine though
Old 06-18-2002, 09:30 PM
tazman
tazman's Avatar
Post
[quote]Originally posted by Luke:
<strong>one of my stock pipes had a hole the size of a quarter in it, so I said "why not" ........
Im having some issues with mine though </strong><hr></blockquote>
I'm curious what "issues" you are having. Is it a problem with hoses blowing off under boost?
Old 06-19-2002, 11:30 AM
Luke
Luke's Avatar
Post
[quote]Originally posted by tazman:
<strong>
I'm curious what "issues" you are having. Is it a problem with hoses blowing off under boost?</strong><hr></blockquote>
well under boost the hose will either slide off, snap the hose clamp in 1/2 or loosen the clamp. It's a new issue every day, and I mean everyday I have to tighten and replace at least 1 clamp SOmebody mentioned T bar clamps? where can I find these. I need something more agressive.
O, but the usual spot is at the throttle body because that pipe is perfectly straight and then it makes a 45 at an inch and a half before the T body. That has to be seriously tough on the connection at that side.
Old 06-19-2002, 12:23 PM
Rob
Rob's Avatar
Post
[quote] Somebody mentioned T bar clamps? where can I find these. I need something more agressive.
<hr></blockquote>
check out <a href="http://www.burnsstainless.com/Hardware/Clamps/clamps.html" target="_blank">Burns Stainless - T-bolt clamps</a>
They also have the materials you would need if you wanted to try and fab up there own intercooler pipes.
Later,
Rob
Old 06-19-2002, 01:34 PM
951Racer
951Racer's Avatar
Post
If the problem is slipping the connections between the IC and pipes, another option is to weld a tab on IC in/out and a corrosponding tab on the pipes and then bolt a flat bar between them. That will certainly hold them together.
Old 06-19-2002, 02:11 PM
Luke
Luke's Avatar
Post
[quote]Originally posted by 951Racer:
<strong>If the problem is slipping the connections between the IC and pipes, another option is to weld a tab on IC in/out and a corrosponding tab on the pipes and then bolt a flat bar between them. That will certainly hold them together.</strong><hr></blockquote>
Yeah, I planned on doing that as well !
Old 06-19-2002, 02:13 PM
Luke
Luke's Avatar
Post
[quote]Originally posted by Rob:
<strong>
Rob</strong><hr></blockquote>
$10 each!!!! OMG $160 in clamps!!!
Old 06-19-2002, 03:36 PM
Rob
Rob's Avatar
Post
<strong> $10 each!!!! OMG $160 in clamps!!!
<img src="graemlins/roflmao.gif" border="0" alt="[hiha]" /> Yea they are expensive, but really nice.
Road race engineering also has some that are cheaper. check <a href="http://www.roadraceengineering.com/hoseandclamps.htm" target="_blank">these</a> out.
Also, do you really need 16 clamps instead of 8?
Later,
Rob
Quick Reply: where to buy intercooler pipes
