80% leak down !! Whats up ???
Since I sprung another oil leak at my last track event, I thought I better check my cylinders for blow-by. The compression and leak down were as follows. #1-#4 compression 115/95/100/60. Leak down 80%/5%/5%/80%. The car recently had head work ! Did my mechanic make a mistake or is this for real? The car was running real strong, and other than the oil leaks and oil consumption under boost, everything seems ok. What should I do?
David,
I hope that he made a mistake because those numbers on the leak down are very very high. Good luck in finding out what is going on.
On a side note, were you in your car on I-77 yesterday, I was driving down to Charlotte and saw 951 that I thought might have been yours going north near hendersonville.
Yesterday, I drove I77 to Mooresville. Must have been another nice one. I guess I'll start planning to remove my engine and freshen things up. Time to locate any and all info. Please e-mail me with any tips or instructions. Thanks !!!!!!
Just a suggestion:
Before pulling the engine apart, do the leak down again and use a stethescope to listen where exactly you are loosing your air. Thsi may help you pin point your problem area.
R.B.
R.B.
