cant figure out idle issues
TPS can't cause the rich condition.... It doesn't control fuel. Only which map the DME will use. Idle, part throttle, or full throttle. Where the throttle is actually at, the DME doesn't know or care.
If you're continuing to show an AFR when your off the throttle when driving, THAT might be the TPS or a stuck injector, but it won't cause a rich condition.
