Wossner Rod Bolts Torque ?
Building my fresh track motor for my ITE SCCA 944T - Anyone SURE how many lbs. to torque the rod bolts?
Thanks in advance
Thanks in advance
its 55 ft lbs. or 0.005" total stretch for arp rod bolts, they might be similar to wossner's. Do you happen to know what the width measuremant is of the BIG END of the rod? Somewhere around 1.132 ? Can you check if you have some calipers handy?
Thank you for your responses - Got thru to Wossner and ARP. I am using ARP bolts. Turns out ARP supplies four different types of bolts with different torques recommended for each type. ARP supplied me with the correct Torque for the bolts I have, so I am set.
VROOM VROOM
Thanks again.
VROOM VROOM
Thanks again.
VROOM VROOM
Thanks again.
VROOM VROOM
Thanks again.
No secret - the bolts I am using need 55lbs. of torque. I do not know what the other types require.
I will try and measure the big end width and post it but I do know we are using ten thousandths clearance between the rods and the crank.
Thanks again.
Thanks again.
