Need definative answer LR chip/Mafterburner
Small Business Partner
There is a lot of limitations in the stock-styled software...
That said, as John mentioned, I released a DIY tuning that only requires the purchase of an chip-emulator. Cost less than most chips, and gives you access to the same maps that most "tuners" adjust.
Link is in my signature.
Professional Hoon
Hi Paulyy, after doing some digging it appears I made a mistake when I said I had a boost enhancer. There is no mention of it anywhere in my paper work and after what you just said it wouldn't make any sense as to why it would be there. My car actually has a LR dual port wastgate installed already and I have an AEM WBO2 sensor to see the AFRs.
Back to my original question does it matter what chip I have in the car if I have the Mafterburner? The car seems to run lean and I haven't really been able to make much of change when I used the Mafterburner software. The chip in the car isnt really matched to all the mods.
The boost enhancer is used on stock wastegates to hold the valve down longer to get the qucker spool.
