Shop lift
So I just sealed the deal on leasing some shop space to store and work on my toys (69 Mustang, the 951 and my boat). Now I need to find a mid-rise lift that is portable because I am sure that I will get transferred again. I have looked at the Ammco Coats brand and the Bend Pak Brand and was wondering if anyone has preference over the other. Or for that matter wants to steer me in another direction.
http://maxjaxusa.com/ I paid ~$1900 shipped. Took my Dad and I a few hours to set it up. You need a hammer drill and they supply the bolts. It takes 5 on each side. I love mine - used it most recently to get the whole car up so I could get all the calipers off for a repaint and then to bleed the brakes/slave. Prior to that used it on my turbo replacement job. It was invaluable. I leave the passenger post in all the time and just move the drivers side when I need the lift. Takes me about 10 minutes to get it setup or broke down. You obviously need good, level concrete to pull this off. My house is 1.5 years old - I didn't do any testing with mine...just drilled the holes, got the torque wrench out for a 100ft/lb on each bolt and haven't looked back. I got a little cracking away at one of the bolts, but I bought some concrete epoxy and filled it up. Here's my post-install thread.
I love mine - a few pics...
I have a bendpak MD-6xp. Lifts everything from 944's to GT3RS's on a daily basis.
If you click on the blog link in my sig, then click on "Tools for the Job" there are a couple of bendpak posts in there when I first got the lift, and then when I modified it for dropping 911 motors.
My space limitations kept me from getting the maxjax, as I would always have it permanently installed, which meant losing parking on the 2nd stall due to it's width.
I assume since you need a hammer drill that you have to anchor something into the concrete. Do you anchor a mounting plate into the concrete? If so I could not use that as this is a leased space.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
If you can’t drill the concrete you will have to use either a four post lift or a low rise lift the goes under the car (pretty useless for any work outside of the suspension).
I've got a 4 post lift with the sliding jacks...I have yet to find anything I can't do on my car. Plus, I like the fact that when the car is stored on it for the winter the suspension isn't haning.
I bought mine from Greg Smith Equipment...it's been perfect for 5+ years.
Rick
Rick
I have the Bend Pac scissors lift purchased many years ago. I have had no issue with it and manage to do everything I need to on my car. When I bought it the Max Jack was not available, or I would have bought the MJ for ease of working on the car. Having said that, I have swapped many engines, transmissions, TT's, you name it and the scissors lift works. It can be a bit of a pain when working on the back of the bellhousing but it still works. Pic below of my car this weekend when I put the engine back in my 968. With the lift I can remove and install an engine without assistance, so it does work well.
How do you figure? There isn't much under the center of a Porsche, even a 951 that can't be worked around. Last weekend I dropped this with zero issues. While a 2 post is by far the best, if you are limited by space, drilling restrictions, etc, a midrise is a great solution. A four post has limitations too.
Only thing I have not been able to do on a midrise is an exhaust swap on a 951.
To the OP, you may check with the person leasing you the space. I can't see a big deal with sinking flush mount anchors into the concrete (for the max jax). When the lift is removed, they are completely flush with the ground, so it isn't like it prevents anything future from going across the floor.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Rick
