Looking for Huntley Racing MAF Wiring Instructions
I bought a '87 turbo that had this old Huntley MAF in a box. I have the LINK documentation [dated 4/92], but missing the MAF wiring instructions [loom still on car but not attached to DME/KLR]- can anyone help? I did a search, but no luck with wiring diagrams, just a bunch of rave reviews!! Does this kit have any value?
Thanks! John
Thanks! John
Box full of obsoleteness?
Huntley supplied his MAF from www.splitsec.com which still has wiring instructions posted on its site. You may be on you own wiring it to the Link, however, since that was not a (typical/common) Huntley set up. Trust you know those parts have been overtaken by a new generation of improved systems.
Yes, to pass the California 'visual inspection' smog test.
Thanks, I'll check out the Splitsecond site. I am aware of the latest "favorite vendor of the day" equipment.
John
John
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Many things have advanced since the 90’s – engine management mods especially!
If you really want to use those parts then warm up the Rennlist search engine and you will find some old advise on setting them up…good luck!
Can't quite tell the spirit of that comment, so will just wish you well with your efforts. I was not referring to any particular vendor or product, but rather wanted to give you a heads up -- if you were unaware-- that modern fuel controllers have advanced a long way since those parts were made (for a price of course).
You don't need any Huntley MAF installation documents. You must use Intercept Link manual. All necessary drawings are there. Intercept link will be connected similar way than AFM Link. Many of us have connected that to DME wiring, so help should be available here.
If you really want to use this, drop me a PM and I will send you some good setup info. You would be better off to get a MAF/Chip kit from one of the vendors that are still in business. If for no other reason, the equipment will be new and the support will be there if things go wrong.
