Cam gear retaining bolt.. to drill or not to drill?
OK everyone, I have destroyed 2 cheese head adapters trying to get the cam gear bolt off my N/A.. bolt just isnt moving..
Should I drill off the head and go from there?
Any reason not too?
Discuss...
Any reason not too?
Discuss...
Yup, just drill straight down the center, slowly increasing in size until the head pops off. Once the head is off, the bolt will turn out by hand. You can take a new bolt and judge how deep you need to drill...it isn't far.
Thanks, wanted to bounce the idea before making myself take the cam to a machinist to remove the bolt... will be drilling tonight! Already have a new bolt on hand, just need another cheese head driver...
Drill worked quicker than an impact!
DONE!
it will be going back together tomorrow.... unless I drop off the housing at the machine shop to clean it all up nice and pretty like!
DONE!
it helps a TON using a torch and just heating up the head of the bolt(till glowing red and smoking) then quickly (before it cools too much) impact it off... I have done this dance about 20 some odd times building engines for customers..... the locktite crap that they use is HEAT activated to loose(burn) up and release the bolt....
Glad to hear that you got it off!!!
Carl
Carl
