TURBOCHARGER EXPERTS NEEDED!
Old 01-20-2011, 11:39 PM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Looks like a #8 housing to me.
Old 01-21-2011, 12:18 AM
TurboTommy
TurboTommy's Avatar
To make 400 rwhp, that hotside is too small.
Old 01-21-2011, 03:33 AM
Rogue_Ant
Rogue_Ant's Avatar
Guys have made more power then that with the Stg III housing.
Old 01-21-2011, 06:44 AM
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
Originally Posted by Clown
I have a 2.8 bored engine and looking to run around 400rwhp
Odd combo, usually its 2.7 by going to a 104mm bore with a 2.5 crank or a 2.8 by using a 3.0 crank in a 100mm bore.
Old 01-21-2011, 09:52 AM
Clown
Clown's Avatar
Originally Posted by Scott H
A handy little file to have:
Chris - I just picked up the engine with a recent rebuild and bore job. If I remember right, I think it was a 106mm bore sleeved but you may be right it may be closer to a 2.7.
What turbocharger do you use on your 951's ?
Old 01-21-2011, 03:32 PM
David Floyd
David Floyd's Avatar
Chris - I just picked up the engine with a recent rebuild and bore job. If I remember right, I think it was a 106 ?
106 bore should equal 2.785 ltr
Old 01-21-2011, 03:47 PM
TurboTommy
TurboTommy's Avatar
That hotside isn't too much bigger than a stock turbo S.
Now you want to use it for almost twice the power. I wouldn't do it; back pressure will be through the roof.
Old 01-21-2011, 05:46 PM
Rogue_Ant
Rogue_Ant's Avatar
Have you measured backpressure?
Old 01-22-2011, 12:21 AM
TurboTommy
TurboTommy's Avatar
Yes, many times with different setups in the past.
Currently have a semi-permanent gauge in the car.
Old 01-22-2011, 01:35 AM
Rogue_Ant
Rogue_Ant's Avatar
And what kind of backpressure did you see with this turbo combo?
Old 01-22-2011, 11:40 AM
Clown
Clown's Avatar
Well you are correct, but we don't all have to be so litteral all the time do we?
After all Porsche calls it 2.479L a 2.5 and its 2.983 a 3.0 and so on and so forth..... but thanks for the correction.
Old 01-22-2011, 01:07 PM
Chris White
Rennlist Small
Business Sponsor
In this case there is a big difference - it's not in the actual displacement, it's in how they got there. 100mm bore with a 3.0 crank is a different animal than a 106mm bore with a 2.5 crank. The tuning and rpm ranges are different - and so the turbo selection would be a litte different too.
Old 01-22-2011, 05:16 PM
David Floyd
Sorry... was not meant to be a correction, the strokers have been called 2.8 and the big bore 106 like yours and mine have been called 2.7, which is why I just put 2.785 in my signature and let others call it what they want....
Old 01-22-2011, 05:24 PM
Clown
Clown's Avatar
Well thanks for making me feel silly for a while I was going to post a quote of yours from a while ago...
David Floyd Quote:
"Mumzer,
I have a new 106mm bore 2.8 engine, boost set at 10psi during break in stage ( manual controller )
Turbo is a non ballbearing Garrett TO4E 60 trim #8 turbine that has been Extrude Honed."
Woops did that slip into my post...LOL
Just messing with you man...I agree they can call it what they want....And we can call it what we want...Sorry man could not resist I just stumbled upon that when researching the To4e 60 trim ....You still running the same turbo what are your numbers and how do you like it?
Old 01-22-2011, 05:55 PM
David Floyd
David Floyd Quote:
"Mumzer,
If you search back far enough you will find I called it 2.82 which is what the builder called it, others were telling me I had a 2.7, hince I did my own calc and came up with the 2.785.
No longer running that turbo, while it was actually pretty good, I upgrade the old MAF I had to Vitesse Racing and made it a package with there stage 4 turbo.
Depending on your tune and supporting mods, 350rwhp at 15/17 psi will be close
Quick Reply: TURBOCHARGER EXPERTS NEEDED!
