F/S: Part out: Parts added 2/1/11
Old 12-28-2010, 03:19 PM
PorscheDoc
PorscheDoc's Avatar
Default F/S: Part out: Parts added 2/1/11
Round whatever. Slowly going through and cleaning out bins in the basement
Prices are shipped in the US only. I can ship overseas, we will just have to work out the freight costs.
EARLY offset Charlie Arms with larger 19mm pins, 1987 Turbo spindles (drilled to 19mm), and 1987 Turbo hubs. Ball joints are smooth, yet are due for replacement. These can be gotten from Wrightwood Racing. Hubs have fresh bearings just packed with lucas grease and are ready to go. Only thing not included are the washer and spindle nut for holding the hub on (had to use those to keep my car a roller at this point). The arms are no longer being produced. Previous owner busted a spindle at some point and the rotor rubbed down the outside of the right arm. Doesn't affect anything, I have never bothered to clean the edges up as it doesn't affect anything, painted to prevent any corrosion. $1500 shipped
AC clear mounting trim: New 2 years ago. I broke the two side retaining tabs, but there are 6 other tabs that hold the clear piece to the climate control unit, so the side ones really aren't necessary. Plastic and mounting holes are in great shape. $30 shipped
Aluminum shift ****, boot, boot retaining trim, shift lever, cup bushing. **** is press fit onto the shift lever (wrapped with one layer of electrical tape and then pushed on, nice and tight. Shift lever is shortened about 1 inch). Lever is very low mileage and was replaced about 3 years ago with the new boot, plastic trim boot retaining piece and cup bushing at the same time. Pin is not hourglassed. Ready to bolt on and go (I did not run the rubber boot underneath the shift boot) $125 Shipped
6 blade radiator fans: $70 shipped
Pagid RS4-4 pads new for non-S turbo (or turbo S rears): $150 shipped
Pagid RS14 black pads. 50% remaining, the one pad has a little chipping on the edge: $50 shipped
450lb springs 2.5"x8" (50 shipped), washer reservoir (for cars with headlight washers) (40 shipped), turbo coolant expansion tank about 4 years old (has a little grime inside for some reason, I will clean that out best I can...$50 shipped), 968 coolant expansion tank, 60k miles ($40 shipped).
Rebuilt driver's side late offset control arm: $100 shipped
Used Radiator. About 3.5 years old, less than 10k miles on it. Fins are a bit bent as I didn't run an AC compressor in front of it, but it cools great. Newer fan switch installed (coolest one). $100 shipped SOLD
Various hoses: $10 each plus shipping
Intercooler to pipe couplers are nearly new
Turbo to piping hoses are in good shape
Low mileage steering rack bushings (the one outlying odd ball bushing is brand new, but can't find it's mate)
Numerous cooling hoses that I had kept as spares. The Y hoses are no longer available from Porsche.
Early offset BBS LM's 7.5x17 fronts and 9x17 rears. Currently cleaning them up, will post pictures as soon as that is done. $1500
Misc engine items. Make offer
JG Bailey Floor Mats: $50 shipped
Fuel sender, alternators, etc: Make offer.
Various engine items: Make offer.
Old 12-28-2010, 03:30 PM
Scott H
Scott H's Avatar
PM'd on ICV and DV
Old 12-28-2010, 03:34 PM
s14kev
s14kev's Avatar
Ill take the downpipe. PM sent.
Old 12-28-2010, 03:41 PM
PorscheDoc
PorscheDoc's Avatar
Thanks fellas, i'll get everything boxed up and out tomorrow.
Old 12-28-2010, 03:46 PM
User 41221
User 41221's Avatar
Geezus, that was fast! lol
Old 12-28-2010, 03:54 PM
PorscheDoc
PorscheDoc's Avatar
See Scott, you could liquidate the contents of that entire storage unit of yours in about 60 minutes!
Old 12-28-2010, 04:32 PM
86 951 Driver
86 951 Driver's Avatar
Don't forget about the local guys. Some good parts here.
Old 12-28-2010, 05:19 PM
mtnman82
mtnman82's Avatar
Damn, gotta be quick on this board...
Old 12-28-2010, 05:32 PM
Josh B
Josh B's Avatar
Dang - would've bought a couple things
Old 12-28-2010, 06:32 PM
PorscheDoc
PorscheDoc's Avatar
Still have a CEP black fuel rail, lines, and saddle adapter for using an oem or 3bar bosch FPR. Just need to get it pulled.
Old 12-28-2010, 10:24 PM
86 951 Driver
Are you going LS? You don't have any foglights do you?
Old 12-28-2010, 10:56 PM
PorscheDoc
PorscheDoc's Avatar
Not sure at this point. I didn't run foglights.
Old 12-29-2010, 12:21 AM
lart951
Basic Sponsor
lart951's Avatar
did you run the injectors with the ballast (resistors)
Old 12-29-2010, 12:34 AM
PorscheDoc
PorscheDoc's Avatar
I did not. I am a bad man.
Old 12-29-2010, 12:36 AM
lart951
Basic Sponsor
lart951's Avatar
I don't think you need them unless you race the car but that wasn't your case wasn't?
