Oil in coolant pics...
As you can see, a lot of oil in the reservoir. Bought new widefire and I'm going to put it in tomorrow...
I'm going to do it with my tech tomorrow evening after work and we will be dirty and pressed for time, so no time for snap shots or pictures, hopefully between the both of us we should be able to do it in 3-4hrs, don't want to be back home after 10pm...
http://members.rennlist.com/tom86951/
Good luck man, hope the head checks within spec and you're back on the road soon.
may have pinched a seal or 0 ring. Just resealed one of mine and also head gasket same time 3 months later found oil in coolant. O ring was the the problem . must have slightly pinched putting housing back together. Have never seen that much oil from a head gasket.
Clifton
Clifton
Clifton
Clifton
When he took the oil cooler housing off, it was fine, had no visible leaks or anything, so he went ahead and put the new gasket in anyway, so when there's mixing it can only be either the oil cooler housing or the headgasket. It may well be the headgasket because when I floored it and took it above 110mph the other day, when it cooled, the reservoir level was really low and I had to ad a half gallon of water and a half quart of oil. When I drive it normal, I don't have to ad oil or water to the reservoir after I check it when it cools off...
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
It never “has” to be anything….I would not make that assumption based on what you posted. Pressure check the cooling system before you pull the head – if it keep pressure up at 20psi then start looking for another cause (cracked head, oil consul seals, etc.).
Small Business Partner
