LS1 kit suppliers, list of avaibale suppliers
#61
yes, I used würth sealant that my friend "borrowed" from his work at mercedes dealership, its not leaking between sump and block at all, just a tiny pinhole in weld between the an fitting, and the pipe.
btw tony, you dont seem to put your videos on youtube anymore?
#62
Rennlist Junkie Forever
Sorry about the pan. Weird. I've personally had two pans, and neither ever leaked.
As far as the videos go.... I put one up on my site ( http://www.tonygarcia.org/944V8 ) . The problem with youtube is that you have to cut the video into pieces and that's a pain.
I have another from that same weekend that's ready. I need to chop both into 10 minute segments and put them up on youtube.
Guess I'm lazy...
TonyG
#64
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
wtf?????//
http://www.gmperformancemotor.com/Me...39323434353439 :thumbsup
that's 480 hp before you install Eric's headers.
#69
Team Owner
killer stuff Robert, as usual....
$1800 shipped to any US-48..... Just PM
Everything needed for a basic swap minus the oil-pan (I suggest getting TPC's) as This kit uses TPC's AC-compatible POWDER-COATED uprights and allows maximum steering rack clearance. The X-member is precision line-bored at the control arms for exact 3/4" drop, relieved at the rack mounts (for max oil-pan clearance) and slotted at the Upright mounts for aft movement. It was then acid washed, primered, and painted . Again, I guarantee your hood will close (with no cutting) even with the taller power steering rack. 3/4" billet X-member spacers and 3/4" longer X-member zinc-plated bolts and washers. 3/4" Sway bar spacers. 3/4" bump-steer tie-rod drop blocks (You will need to get a set of MANUAL rack outer tie-rods...Rock Auto $25/ea). Bolt-on Modded 13/16" Wilwood MC and custom adjustable pushrod adapter (Includes Wilwood accessories). 30" -4an stainless braided line and Wilwood NPT adapter. Brand New Anodized and Pre-Modded C5 throwout bearing with -4an lines included to fit the C5 Bellhousing adapter with TT mounting hardware all included. Your chioice of an LS or LT/SBC pilot bearing adapter and new pilot bearing. I redesigned the 1/4" thick 2000 series alloy brake MC adapter for factory 944 MC and a longer custom adjustable pushrod adapter. It has a seperate billet plate that removes so the larger firewall plate can be re-used for Hydroboost or Dual MC mount later. Kit comes with New construction 4140 custom steering shaft with brand new Borgeson U-joints made for the 3/4" X-member drop. It is adjustable due to the Double D ends. Comes lengthened exactly 1/2" but can be extended or shortened by end-user.....Also included is my new universal billet-polyurethane transmission mount (85.5-up only) that set the drivetrain at factory position or 1/2" back for the V8 swap with swappable set-screws..... And to sweeten the pot, I'm adding in one of my Short Shifters, all Chromoly design with Teflon Heim....
#72
Stay away from RH kits. Having worked on A LS6 conversion recently with a RH kit, I can tell you that the majority of the kit is cheaply made junk parts. Might be good for a weekend hotrod, but a for a serious professional installation, thier kit will not be satisfactory. Soon everyone will see the correct way to install an LS conversion.
#73
I have to disagree with you guys I have had RH kit installed in my race car for 2 years. The 1st year with the swap I won many races in my class & finished 2nd in my regional championship.
In 2011 I again won many races, won the regional championship & finished in the top 10 at NASA Nationals @ Mid Ohio. BTW i didn't have any DNF's all season! So i would say the RH kit is reliable & works well in a race environment.
RH has stood behind there products & has been great at customer service. I did not have time to re invent the wheel I bought what was available & moved on I do not regret the decision to use RH kit.
