Variable Intake Manifolds
you could use a split plenum with different size throttles kind of like a BMW 318i, even though that motor only had 1 length runner.
one smaller throttle would have a longer air path and the larger throttle would have the short, high-rpm air path. i imagine you could do a progressive throttle opening where like depending where the throttle position is, the small bore would be open fully and the large bore like halfway and then at WOT above a certain rpm both are fully open.
WHat no one has shown is a true, variable intake. Dual runners, yes, but not variable. This is a design that I think Cosworth patented a while back. As you can see, and as Chris pointed out - it takes quite a bit to package it:
![](http://blog.autospeed.com/static/images/articles/i19/1969_2mg.jpg)
Everyone geeking out on this stuff, don't mind me, but there is not nearly as much to be gained from this in the 951 as some of you may think. I still think that VCT would be both more beneficial, and less complicated.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
If you have some time read this thread (one of the best intake threads I know) – its really very interesting and I have to commend the guy making the intake manifold – he did his homework!
Warning! You will get sucked in to reading all 19 pages….there is a really good progression of design. If you just look at the final product you will miss the whole design process!
http://forums.hybridz.org/index.php/.../page__st__320
I apologize in advance for taking up an hour (or more) of your life (it’s worth it)!
