Issues w/ installing the AC compressor and Alternator
Hey Guys
Are there any tricks to installing these on the bracket ... I am having an issue trying to get on the AC compressor on to the bracket it hangs from ( to say its a tight fit is an understatement.... And I assume the Alternator will pose the same problem ... There must be a trick that you wrench heads out there know to help get this on .... It's either that, or I gotta get back to the gym, and Hans & Frans some ....
TIA
Ed
TIA
Ed
Hey Jason
Actually no ... I just cleaned it ... I am thinking of using a jack cushioned from underneath and seeing if that will push it in... I wish it were warmer here, than I could do the hot and cold thing, and that may make the difference here ...
I didn't want to heat the bracket as its sealed ( except were the contacts are, with Zoop seal ) There must me a trick here...
This thing is tighter than a clams *** under water ....
Regards
Ed
Regards
Ed
No trick involved, take a file and file down the mounting ears on the new compressor/ alteenator by hand a tiny bit until you still have a snug fit but can still push the compressor / alternator into place by hand. Keep the file and the filed surface flat/ even. Do not use a grinder as you do not want to remove more metal than is req'd to get the snug fit. Do not file the mounting bracket bolted to the engine as the next compressor or alternator replacments may be the exact same size as the ones that you removed today.
There's no need to grind or file anything. Look at the aft mounting ear on the bracket. There's a bushing that needs to be knocked back a little to make room for the compressor. I just take a long extension and give a good whack or two. When you install the compressor and tighten the rear bolt, it will pull that bushing back into place.
I really didn't want to take a file to it ....
What CurtP says is true if the bushing is the cause of your problem. Since this is your old unit being reinstalled I agree with him as it did fit before removal. In my case this bushing had already been tapped back by me until its leading edge was inside of the bracket mounting ear and the compressor still would not fit. The only thing stopping it from being fit into place was a slight diff in the thickness of the ears on both the compressor and altrnater compared to my removed units and both new units had come off of of anther car.The diff was confirmed by measurment so out came the file. Good luck with your installation.
Thanks Curt
Regards
Ed
Spanky
That bushing goes all the way through. If you used just a clamp, you may have just squeezed both sides of the bushing and it won't go anywhere. It takes a pretty good whack to move it, but you don't need to move it much.
Ed
Well I tried hitting that bushing ...
Hey Guys
Just an update Thought this might help the next person that attempts to do this
I whacked the crap outta that bushing .. it didn't move
So, I decided to use my floor jack and it worked like a charm
I rubbed the contact points with Tri Flow just to insure it will slide easier
Here is a pic
Best regards
Ed
Here is a pic
Best regards
Ed
