LED Headlights? Strips? Side Lights?
I'm fairly certain that you'd get much better light output with a Rennbay Harness and his Hella Ecodes and Hella bulbs. It'd be much cheaper too.
I'm running a IceShark Harness with Ecodes and 130/90w bulbs and can tell you that it's brighter than my neighbors new BMW 5series. My car also doesn't have a dangerous glare associated with many of these "cool looking" lenses. Another note is that this setup allows you to upgrade your Fog/Driving Lamps at the same time.
The only reason I went back to a "regular" bulb was availability.
130/90 Yellowstars FTW!
http://www.rennbay.com/hella-yellow-...90w-p-116.html
Geaux Tigers!
Originally Posted by supes6
+1
Even when aimed properly, a 130/90w bulb is some serious wattage and will definitely get people's attention
Read up on E Codes. Oncoming drivers get less glare with these lenses than with standard American lenses.
Not my pics but the below is what I installed. First is a before with standard 951 bulbs on low beam:
After with the Light Cannons on low beam:
Ebay lenses will not do that for you.
Are you sure the "before" pic isn't fog lights? I've never seen sealed beams with that bad of a pattern!
At any rate:
wiring kit $125
E-Code kit: $65
Bulbs: $12
~$200
So for the same price i ended up with 35w bi-xenon HIDs that are just as bright but have a real cutoff, and use 1/3 the juice ($10 more buys you the 55w). If the e-codes were half as much i'd have thought twice about it...
These are kinda cool, and you could put them in an ebay housing:
http://cgi.ebay.com/ebaymotors/2-PC-...#ht_3453wt_939
(Lots more like that)
At any rate:
wiring kit $125
E-Code kit: $65
Bulbs: $12
~$200
Geaux Tigers!
I took the pictures from another post by another Rennlister. Looks like fogs and low beams to me.
Originally Posted by These are kinda cool, and you could put them in an ebay housing:
[url
[url
http://cgi.ebay.com/ebaymotors/2-PC-WHITE-H7-18-LED-SMD-FOG-XENON-LIGHT-BULBS-/220704206829?pt=Motors_Car_Truck_Parts_Accessories&hash=item3362feefed#h t_3453wt_939[/url]
I'm sure those bulbs are awesome, hell they might even shine past the bumper, especially in an ebay housing, lol....
found some interesting info on the yellow star bulbs:
HL78155Y - 60/55W 1650 Lumens, 175 Avg Hr life
HL78158Y - 80/70W 1,825 Lumens, 130 Hr Avg Life
HL78159Y - 100/80W 2,900 Lumens, 100 Hr Avg Life
HL78160Y - 130/90W 3,400 Lumens, 50 Hr Avg Life
50 hours for the 90w bulbs, depending on your usage this could be only a couple of months.
Geaux Tigers!
LOL, did I mention that the Hella 130/90 bulbs cost about the same as a meal at Taco Bell?
On a side note you should not run this wattage without upgraded wiring.
I could eat at Taco Bell for a week for $12!
Yes, you could put an HID kit in the e-code lenses.
