Oil Pressure Releif Valve question
My question is this, do I need the special alignment tool for the cooler cover while using the 3 piece oil pressure relief valve?
::Curious minds, read below::
My car has had at least 2 oil leaks recently...
Apparently I installed a cam seal that was too small and didnt realize it until it actually did start leaking about a year later (that one is fixed).
I have an oil leak coming from my oil pressure relief valve bolt... since I do get the occasional gunk on my oil cap, i figure that maybe I should pull off my oil cooler thats on the block.
