Massive part sale
1 Post
Massive part sale
I did a bunch of work on my friends 86 951. We replaced a lot of stuff with some upgrade parts. All the takeoffs are for sale now. All prices are OBO and plus shipping from 85730.
928 GTS master cyc NEW $300 asking $200
Used 928 Reservoir included with master
Script door handles No locks $50 sold
Sachs struts they have 15,000 miles and bought in 2007 fits early offset new price $730 asking $200 with springs.
Turbo clutch 10, 000 miles includes pressure plate and flywheel, went to a KEP and fidanza . the distance to the rivets is .037 new is .046 $150
KYB rear shocks 15k miles $20
Sway bars front and rear 86 turbo stock $75
Sway bars front and rear Turbo S $200
K26-6 130k miles $100 sold
Bat wing no damage $150--Sold
Script door handles with locks $75 sold
86 hubs, and spindles for turbo $150
More to come!
More to come!
interested in the following items:
shipped to So Cal 90201 where do I send paypal payment.
Rick
Rick
1 Post
More stuff to add
Turbo and NA valves all good and some sets are newly ground. price varies and sold as sets of 4.
nearly new diverter valve $50
Turbo water pumps $30
Oil cooler with shroud/duct $40 SOLD
stock 88 sway bar $40
Turbo S front sway bar (not pictured) $75
New Empi CV boot kit $15
Turbo blinkers $30
Flag mirror bras. If you can sew these need a little repair but vinyl is good $15
10 Speaker door panels. includes arm rests, speaker housings and covers. the back side is good with epoxy resin to fix some degradation and the black should be recovered. $100 SOLD
T bolt clamps 2 5/8 id open $10 for 4.
Turbo nose. Cracked on lower support but repairable. Great for a track car ok for a street car. See post below for more pictures. $175
Turbo blinkers $30
1 Post
And more....
88 axles. Good boots, ok joints $40
Clutch master and slave taken apart to check seals. Use for parts or reassemble. $30
Cup Pressure plate with bearing $90
Cup pressure plate no bearing $40
Stripped control arms early and late offset $25 ea
Turbo hard line and silicone hose $25
Headers. Welded flanges on 2,3 and VDO K type thermo couple in #4 $100
Kick panel carpet. Carpet good, the fabric that wraps under the weatherstripping needs to be replaced. $20
Fitch Fuel catalyst for a diesel engine. http://www.fitchfuelcatalyst.com/ Over 600 new, never used. $300
Radiator, stock turbo $75
Aftermarket radiator for turbo. Requires some fitting work. good for a race car. See more photos in next post $150 SOLD
1 Post
more.....
Generic fuel pressure regulator $10 sold
Turbo oil feed $50
QA1 rear shocks, adjustable and threaded with adapter bolts. I will include a set of spring seats $50 sold
New Tial silicone hose kit for 944 turbo with stock hard pipes includes T bolt clamps $130
New Sanden r134a compressor not made for the 944. V belt pulley. $200
turbo fog lights. Real euro light with stoneguard but is cracked. $30
Fog light with extra reflector. $30 Sold
Door lock solenoid $10
nearly new 2.5 bar fuel pressure regulator. $25
Idle valve $20 SOLD
Late style strut mounts good rubber and good bearings $75
Turbo oil feed $50
Idle valve $20 SOLD
1 Post
still more.
Cone filter adapter to AFM $10 sold
Turbo fuel pump runs but unknown age $30
New Anco contour (no metal frame) 19" wiper blades. I have a few sets. $15 per set of 2.
Boxster S 17" wheels 7 and 8.5 wide. the front is mismatched with a standard Boxster wheel that is the same size as the S. These are good track wheels or refinish them. $300 for all 4
left side 968 control arm $50
