Use of Larger Radiator
Is anyone using an oversize (comapred to stock) Griffin radiator in a 951? I would like to try a higher water cooling capacity to keep fluid temperatures down instead of a second oil coolerin my 944S2 race car.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
https://rennlist.com/forums/showthre...rid=1956<br />
https://rennlist.com/forums/showthre...eferrerid=1956
I am not sure I understand how lower fan switch and thermostat would be useful on the track. A larger oil cooler is an option, but I think a larger radiator has more benefit for both water and oil.
You could take a look at this solution…(I may just be slightly biased towards it!)
I have looked at and considered yours as an option and would have gotten around to talking to you about it before next spring (plan a solution over the winter). Two questions and please understand that these are not meant as disparaging your design. Do I actually have higher water cooling capacity over stock radiator given that an oil cooler is fitted in the same total surface area as stock unit which I interpret as less room for water. Is the oil cooler more Vulnerable to damage in that spot due to front impact?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Chris,
Thanks[/QUOTE]
I never consider questions (at least honest ones!) as disparaging remarks – its much better to have an educated customer than one that just responds to hype!
The radiator is much thicker than stock – in fact it is as think as possible for the space so the total fluid capacity is the same as stock or possible a little more. The cooling capacity exceeds a new stock radiator and greatly exceeds a 20 year old stock radiator.
To damage the oil cooler you would have to get to the point of bending the radiator support frame – if you do that you will have totaled your car! The stock oil cooler would be damaged as easily as this one. If you are worried about damage from a foreign object remember that the A/C condenser is in front – in addition if the worst happens aluminum coolers can be patched easily by a decent welder.
Here is a pic showing the difference in thickness
Thanks[/QUOTE]
Thanks Chris. This certainly makes sense. I can also leave the stock unit where it is and plug it in case i have to run two oil coolers if needed.
