APE Maf potentiometer broke.
Can I just go to radio shack and buy one that tunes to 2.2k ohm? The one they supply isn't anything special right? Might be a dumb question. Also, it has to be 2.2k acorss the connector leads, anyone know how much added resistance is is the unit and the wiring so I know what ohm range i need?
And on the AFM, the air temp sensor resistance is read on the last two plug terminals. Therefore, the APE potentiostat, basically acts as the air temp sensor i think, should also read on the last two terminals right?
You knowledge on MAF systems is amazing.
I just wasn't sure because there's an old thread on the pelican forum where some 911 driver had his pot break. He ordered a new one from APE under the advice of another 911. for 90$.
