Remove head w/o removing studs?
I have the turbo off and downpipe out. Could I unbolt the head and lift out and away from headers so that I don't need to remove exhaust studs while in the car?
Alternately, is there a brilliant way to remove the head without removing studs?
Thanks for the advice...I've broken/stripped enough bolts for today (what is the quota for these cars?)
Dan
Dan
Head and headers can come off together. Disconnect the headers from the x-over pipe (6) bolts and remove/install them while attached to the head. Pretty easy.
I did it with PB blaster, and after letting it sit I hit it with a hammer like twice(gentle). Then vise grips should do the rest. If it's still stuborn to come out use some heat.
