who is running autothority chips and a MBC
i am trying to track down a running problem on my 951. I need to know if anyone is running a manual boost controller with autothority stage 2 chips. I am thinking this could be part of my running problem since I deleted the stock cycling valve.
thanks
thanks
I'm running 18 psi on autothority chips with a 3 bar fuel pressure regulator. No running problems here.
I would check for boost leaks and loose vacuum lines... For some reason they just always appear every few months
Doesnt boost nicely, meaning? Sometimes it doesnt make boost, sometimes it does? Or sometimes it has a poor throttle response, boggy, laggy?
Intermittent boost level problem running a mechanical control system - I would look at the waste gate and the MBC itself, something could be sticking open/closed.
i was running 21 psi with mbc and the stage 2 when i first got my car. i had similar problems as you after my friend StrekStrekStrekStreked with my boost controller and broke it. worked fine after i put a new one in
thanks
umm im not sure what broke. my ex friend kept turning and turning it over and over again. i took it apart and there was a seal that was all messed up. i replaced the seal and it still didnt work. i put in another one i had laying around and it worked again. i had 3bar fpr, super shimmed stock wg, stage 2 chips, k26/6, LR 3". i couldnt adjust boost and sometimes it would feel like the car wasnt at 21 psi and would feel like it was at 15psi. i didnt have a gauge installed at the time so i couldnt see what boost really was.
