want to remove this to relocate my Saiko Michi CC. Can it be removed from above or does it need to come out from below and remove the wheel well liner? I'm hoping for option #1.
Any tips?
I with Fluidplay on this one. I swear the longer style wash tank was pressure formed in place on the car like a balloon. What a PIA to remove with or without the fender liners.
To be completely honest I cannot remember. I had the coil removed and disconnected the headlight motor plug. I just wiggled it out of there! I also had the power steering lines disconnected.
LOL, It really looks as if it was...so Steve, you pulled it out from below?? I'm at that point where I'm just going to remove the liner.
Mine is an 86, and it was worse than replacing the PS rack. I think I actually loosened the oil cooler, removed a big bracket, some other stuff, then still almost used a come-along to pull the thing out. The later model small tank was very appealing as the replacement, but I went with an original.
