Do i have to pay $400+ for undersizes mains
got my self a otherwise realy nice knife edged drilled polished 3.0 cranak on ebay
but i need .5 under mains generally pelican is competitive price wise i hope they are not in this instance ..
any sujjsestions ?
any sujjsestions ?
You can always take it to a machine shop and have them bring the mains back up to standard; the main bearings would be cheaper but then again the labor would offset the savings
Personally, I dont like undersize journals on engines I assemble.
Yeh sub arc welding the the crank then straitening then then regrinding / re hardening is probably a $700+ operation .
So it I'm realy the only tin **** who thinks 400$ for bearings is offensive?
Think there is some other bearing out of some other engine that can be made to fit with a little machining .
I managed to find some alternative bearings .75 under for the big end s for another one .
perhaps io need to just spend a few hrs in the bearing catalog again..
Small Business Partner
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Yeah, well you will wonder why you didn’t jump at that price really soon….
Glyco – the only manufacturer of 944 bearings has ceased production of undersized bearings…forever.
I checked in with Porsche a couple of weeks ago – there were 3 sets of undersized mains left (in the world!)…so I bought them.
BTW – a crank that needs .5mm undersized bearings is a 2nd undersized - .25mm is the standard 1st under sized bearing. That means the crank was badly damaged and its also possible that a .5mm cut will remove most of the heat treating…I would pass on that one.
So now even if you can pay…you can’t play anymore. I hope this isn’t a trend for the OEM parts producers.
