Rotor delete cap?
Rotor delete cap?
Since I plan to run a coil per cylinder set up, I won't need the cap and rotor and was looking to cover it. Is there such a thing as rotor delete cap?
Also not sure what can be removed besides the rotor. I assume what I am looking at is the cam end, which the cover will have to cover? Or can more be removed w/ housing cover opened?
Steve
Steve
I will check w/ CW on Mon. TO remove that piece, I assume I need to remove the housing to get acess to it.
Edit: Never mind, self evident. Need to have off anyway for bolt/nut placement.
Steve
I've seen one on CEP's site before too that looked really nice. Blends in nice with the belt covers with a nice CEP logo embossed on it. It replaces the entire belt cover piece that covers the cam gear.
DTA- s 60 pro. EMS w/ coil on plug set up. Not really a kit. Wayne at TPG is going to tune the following coil packs. They had the spec's he liked, and the size an design I liked.
http://www.msdignition.com/Products/...il,_2_Pin.aspx
I will probably go w/ CW's, mostly because I dont' really want a logo on it. But I do like the design of the CEP.
Thanks for the help.
Steve
Steve
Hats of to Chris, and thanks to Darwin.
Nice craftmenship. I thought about spray painting the covers as well,but didn't. I fiqured in time it will dirty up. Not sure how well the spary paint will stick to the plastic covers.
Steve
Steve
