Throttle applied when braking
Now here's a weird problem I haven't full diagnosed yet. Let's see join me in analyzing the problem
Symptom: when I brake, throttle is applied.
Facts:
I haven't had time to investigate more. Perhaps a cracked firewall? But it's strange that it only happens when stopping the car from rolling forward. There's nothing loose around the throttle cable in the engine compartment. But it seems that something is flexing that pushes the cable which in turn tensions the wire. Weird little problem
Facts:
- It's not vacuum related because it's the actual throttle cable that is being tightened.
- I replaced the throttle cable without any change.
- There's no interferance or sound proofing or anything under the pedals
- Throttle is not affected when braking when the car is still or when reversing. It's only applied when stopping the car when rolling. Super easy on the brake, not so much throttle. Heavy braking, about 20% throttle.
- I can force the throttle pedal back to 0% position but the tension is still in the wire. To fully remove the tension I have to apply full throttle.
- The throttle wire/cable runs without interferance from the firewall to the engine.
Facts:
Facts:
Check your tranny mount too.
Duke, wake up!!! We want to know if it's the motor mounts....
http://www.worldtimeserver.com/current_time_in_SE.aspx
The suggestion that it is the motor mounts is interesting, but that would also translate into the same amount of forward motion of the transaxle, since the two are connected.
If so, he's gonna need a bigger return spring on the throttle body....a lot bigger.
Sorry, I'll go now.
Duke, does the shifter move forwards when this happens?
