FS: New AOS with new oil cap
Unrelated sorry, but in this photo, what is the opening just to the right and slightly higher than the lower AOS port?
I have removed my AOS to replace the o-rings while I have my turbo off and see that this opening is, well, open! I guess this is where the bad breather type smell has been coming from!
What should be in there? Can't see anything in PET.
Should it be blanked off???
Regards
Graham
Regards
Graham
It sure looks like it goes somewhere - it's difficult to see using a mirror but there looks like a machined hole of about 1cm diameter sitting at the very bottom of the recess
Maybe I'll block it off just in case.
Thanks again and good luck with the AOS sale!
Best Regards
Graham
Hi, thanks for the reply.
Best Regards
Graham
Best Regards
Graham
Thanks for the confirmation. A close up of the hole would be interesting, just for curiosity, but I do believe you both! I'm, just used to the '88 Turbo S having unexpected differences to other 951's.
Best Regards to both.
Graham
Graham
