Hose Kits for 944 Turbo
I was considering the venturi delete kit but the Lindsay diagram doesn't have any info on the crankcase breather. I have the original single hose wastegate and no modifications.
Any suggestions or do I need to chase the later metal pipe and check valve. If so and being in Australia I'll keep the venturi and just renew what needs renewing.
Basic Sponsor
http://www.lindseyracing.com/LR/Parts/HOSES.html
If you go with a MBC, and our long AOS hose, you can eliminate that metal pipe. It would be very difficult to remove the large from the small, or the small from the large in the metal tubing. It's all no nothing as it's welded together pretty tight.
We have several of the hoses now, and will have all the hoses illustrated on this page mid September. So you can change everything and keep stock, or change bits and pieces as to your direction of mods.
Feel free to contact us directly if you're having difficulty deciding what all you need or what to do.
Mike or Dave Lindsey
U.S. 1-877-943-3565
Other 1-405-947-0137
U.S. 1-877-943-3565
I just did the entire hose system on my '87, all new coolant hoses, all new vac. hoses (everything under the hood!) and did the venturi delete. I live 10 miles from Lindsey and I can say Mike has never once not seemed happy to answered any of my questions, great crew.
I did a pressure test earlier this year and even though there's only 72K miles on my '87 it sounded like a colony of hissing cobra's with all the leaks. Had the injectors bench cleaned and flowed and it all made a huge diff. in how crisp the car now runs. Well, crips for a stock AFM 951 that is.....
Replace it all and don't worry about it for 10+ years.
