FS RX7 oil cooler $70 shipped
Rainman
In good shape, could be degreased a little more but I got most of the dirt and outer stuff off (for the record, the black thing on top of the cooler is what remains of some foam used to cushion the cooler). Has both hose ends in case you want to reuse the fittings. Come with stock rubber mounting blocks too. May need new crush ring on the thermostat.
Popular upgrade for 951 guys; about 2.5 times as long as a stock 951 cooler and more rows for oil to flow through. Fits in front of radiator.
PM Sent
Rainman
Sadly not this current bunch, I might get $10 for that pile...one time I made $80 in a single run though! A benefit of living and working in the dorms, and having universal key access...
