951 engine compatibility 1986 - 1988
07-25-2010, 01:08 PM
If you drop a 1986 engine into a 1988, what considerations need to be taken? Does the DME need to be swapped out (24 vs 28 pin)? What else?
07-25-2010, 05:09 PM
AddictRennlist Member Rennlist Small Business Partner
Nothing really - the oil level sender will not work.
Either DME will work fine.
07-25-2010, 06:31 PM
Quote:
Originally Posted by
Rogue_Ant
Oil level sender? Is that something on the 86 but not the 88?
07-25-2010, 06:43 PM
shiners780
On the 88 not 86
07-25-2010, 06:48 PM
I don't recall my 88 having an oil level sender. (We're not talking about the pressure sender are we?)
07-25-2010, 06:49 PM
No - your 88 had a level sender and a pressure sender. The 86 oil pan does not have provisions for both.
07-25-2010, 06:51 PM
There's no gauge on the 88 for the oil level, did the sender just signal the warning light in the instrument cluster then?
07-25-2010, 07:03 PM
Yes just a warning light on the later cars.
07-25-2010, 07:18 PM
The 3 bolt triangle thingie next to your oilpan drain on your 88 is the level sender
07-25-2010, 07:25 PM
07-25-2010, 11:49 PM
07-26-2010, 12:02 AM
1986 ,
1988 ,
86 ,
944 ,
951 ,
car ,
compartibility ,
compatibility ,
engine ,
gsxr ,
porsche
