going fn nuts with clutch line replacement
HELP!! I've successfully replaced the clutch line - almost. Line is attached to the steel line from the master. It's attached to the slave - both are still loose. I cant get the damn mounting clip that attaches the solid line to the torque tube. WIll the car fall apart if I dont put it back on.
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
The car won't fall apart, but if the metal line is not stabilized, metal fatigue can set in and crack the line from vibration. Where there is a will there is always a way.
Cheers,
Larry
Cheers,
Larry
The car will fall apart. This is just a matter of sooner rather then later. I hate it when a PO hasnt done things right. Judgement Day is coming, do you want to Fly or Swim?
