wastegate
OOO you dont even know!I can never sell this car ,if youve seen the cash ive put in this thing ,in the 4 months ive owned it you would faint.It just got out of the paint both.So i ordered fabspeed 3 in ,and wastegate,do i get chips from vitesse ,i will be getting m.a.f. and stuuf from him.will my car run o.k. without chips ? oo and do i shim the wastegate? thanks for all the help!
Your car should run ok with a testpipe and a catback. Many people have upgraded just those parts and lived with it. The Tial wastegate does not need shims but adapter plates to fit correctly. Or you could get a upgraded "stock" (now dual port) From Lindsey racing that will fit bolt on. I prefere the tial as i own one :-D .
Not sure what you mean by that other info if you buy a Maf from vitesse he will give you a chip with it .
No i dont have that Downpipe. You need to take the turbo out to install it anyways. You wont need that with the stock turbo . Anyways if you go for the exhaust you plan and later a Maf you will love the spool-up and sound . Sometimes (only a Few) I regret a little that i went to far with the mods, the car was quite fun with the stock turbo,stock boost,3" exhaust, and VR MAF ..
300whp with a stealth setup will be quite hard. Not only do you need a bigger turbo,stealth maf,bigger injectors,fpr and crank up the boost. It will cost allot and the stealthy stock airfilter does not flow that well. I say aim for around 260whp more than enough for these cars unless you track it and even then that might be enough.
