Drive train - Remove as one!
After a "houston we have a problem" moment which included a blown motor and resulting fire I am in the process of taking out the entire drive train and media blasting the underside of the car. The transaxle is being removed as well to facilitate the installation of an S2 ring & pinion.
We practiced last weekend by accomplishing the same task on my spare wrecked '87 951. It was pretty cool so I wanted to do a thread on the next one.
first photos - getting started
These photos are from last night, just getting started.
Pulled wiring through the fire wall
Dropped the radiator
Removed intake
Removed sway bar
and....a few other bits
Removed intake
Removed sway bar
Cryo treated a new ring and pinion from the fatherland purchased through Eric at G Box. I already have a GT Dif, Kokeln mount and Lindsay short shift front and a custom shift block on the trans.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I got your email – I have a mental block when it comes to linking real names with screen names. When you mentioned that you emailed me I only made the connection because the cool fireball picture showed the car with your last name on it!
I once instructed somebody for most of a weekend before he told me his screen name….and then I realize that we had swapped posts before – and I knew a lot more about his car than he did!
pull fascia (four bolts)
Removed the radiator (for protective purposes)
Coolant hoses
clutch hydraulic line
exhaust
dme/klr harness
shock bolts - top
fuel filter
torsion tube carrier bolts
trans cooler bracket
front sway bar
disconnect A arms
starter shields
two tunnel brackets
and a few other bits I have forgotten
Then, in the rear, all we have left is two bolts on the trans carrier bracket. In the front we only have the four bolts holding the front cross member.
Lift body to seperate.
Coolant hoses
exhaust
dme/klr harness
shock bolts - top
fuel filter
front sway bar
disconnect A arms
starter shields
two tunnel brackets
