My Turbo RS Part 2
I've had to take a couple weeks off my build to take care of some stuff.I spent a good 30 min on the phone with Dave at Lindsey Racing today.He was very patient and helpful making sure I got every little gasket,o ring and nut.So by next week I'll get started on reassembling alll this.I still need to pick up my camtower from podercoat and polish.Thanks again Dave !!!!!!!! JOEL
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Where did you get that waterpump? I haven’t seen a pump of that design in a real long time – no belt guard. Is it really new or is it a rebuilt pump? BTW – most places only have the turbo pump now, they supply an undrilled turbo style plastic hose connector as a block off plate.
I am also intrigued with the stripped apart tensioner – are you modifying that?
Nice list of parts – looks like it will be a rocket when you are done.
Thanks Chris,the waterpump came with the VR setup I got from Jeremy(2bridges).As far as the tensioner,my mechanic removed it so we could clean up some grimy bits.Are you seeing a problem I'm not aware of?Thanks for your comments,Joel
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Most folks remove the three mounting bolts (on the bracket still on the block) and remover the tensioner without taking it apart. It’s a lot easier!
pictures
All cleaned up and have all my parts except a BOV.Starting assembly this week,and looking for a BOV.Anyone have any ideas who has the best price,I don't think I want to use stock on my LR hard pipes
I ordered couple pieces from Forge Motorsports.We had to pull the head and send it out for some machine work.Simple rebuild,replace one intake valve,seals,guides and LR steam vent kit.Finally next week we can start putting it all back together.
Well after finally getting broken bolt out from waterjacket out,we can get to reassembling next week.Really starting to understand why these thing can take sooooooo long to get finished
LR ultra mounts
WE installed LR ultra mounts today.This weekend we'll address the water passage bolt on the block that broke off.We've already drilled it out to replace with a nutzert.Still alot to do.Joel
getting some work done
Well we're moving ahead finally,heads on and headers.I'm starting to replace hoses.I just need to pick up a couple things I forgot to order.
