Ideas for moving car w/ front suspension & wheels off.
Old 06-22-2010, 01:17 AM
Adam Poland
Adam Poland's Avatar
Originally Posted by 67King
You may be surprised at this, but you will be able to relatively easily pick the front end of the car up. If you've got help, just use a couple fo people to move it. Much easier than you think.
+1
Old 06-22-2010, 10:24 PM
DrZ1
DrZ1's Avatar
I agree, but most of the time I will be by myself.
I decided against the trailer hitch and coupler thought, Too much work. Esp when I stopped by a shop that does some welding for me. He had an old cart that the wood had all rusted, but the casters are heavy duty and welded to the angle iron.
I removed all the old bolts securing the wood decking, and replaced w/ some seat bolts, that were slightly stripped and not going back. Not really needed, since spot welded, but looked better.
Anyway, I will have a place welded on top, then place some sort of bearing swivle between the plate and the crossmember( or angle iron) . Also will have a short handle that let me turn the wheels.
Any idea of what I can use to allow about 130 deg or so rotation between the wheels and crossmember, preferably w/ ballbearings??
Any Idea the distance betwwn the bottom of the cross member and the ground?
Quick Reply: Ideas for moving car w/ front suspension & wheels off.
