WTB: 55lb fuel injectors
Looking to buy 55lb fuel injectors for a 1988 Turbo (non S).
If you bought new and never installed I am interested. If you have a lightly used set because of an upgrade to larger injectors or such, then please let me know.
Private Message is best.
Thanks.
Thanks.
Might I suggest http://www.injector.com/cart/pc/view...4&idcategory=7.
Pretty hard to beat $60 a piece!
Thanks JohnKoaWood. Good option to consider.
Small Business Partner
Those injectors have a "pencil" spay-pattern. You would be better off with a cone-pattern - much better atomization, which will give better idle/low-low response and drivability, such as:
Delphi 55lb
Or:
RaceTronix 55lb
$52.61, and $49.50 respectively.
-Rogue
Delphi 55lb
Or:
RaceTronix 55lb
-Rogue
Drive-by provocation guy
Good timing. This is a current thread from TheEdge:
"75lbs Delphi Low Imp Disc/Multitec Injectors - Flow matched set of 4
http://www.racetronix.com/17113742FM.html
E85 Compatible
I bought these brand new from Racetronix, I used them for a while in my 2.7 liter big bore. They have about 4k kms on them and worked perfectly.
Asking $180USD + $10 shipping."
Get these and be done with it.
E85 Compatible
