Build start of '89 951
#47
There are actually 3 cats that live in the shop. The one in the picture will crawl up your leg and mash his face in yours lookin' for a little love!!
#48
Quick update. I can finally see the light at the end of the tunnel!!! I have some good friends to thank for all of this getting sorted!
1. Billet fuel rail with remote regulator and damper (Lindsey Racing)----------DONE
2. Dual Port Wastegate (Lindsey Racing)---------DONE
3. Older MAF2 (Lindsey Racing)------------Needs doing
4. Spec 2 clutch and lightened flywheel with rear main seal---------DONE
5, 4" Exhaust (Lindsey Racing)------ALMOST DONE (Wastegate pipe does not align...off to mufler shop)
6. O2 sensor and gauge, boost gauge, manual boost control------GAUGES IN, need hook-up
7. New ignition wires (Lindsey Racing)-----DONE
8. Stage 1 intercooler (Lindsey Racing)-----DONE
9. Lindsey Racing Chip
10. short shift kit (LR)-------DONE
11. 3 piece cross member (LR)-----DONE
12. #53 stage 3 turbo (LR) dry------DONE
13. 55lbs Siemens flow tested injectors (LR)-----DONE
14. New plug wires (LR)
15. knock sensor wire (LR)------DONE
16. billet blow off valve-----needs doing
17. MAF trap (LR)
18. Ultra Mount transmission mount. (LR)------DONE
19. Delrin front sway bar bushings (Racers Edge)-----DONE
20. Complete front seal kit (Paragon)------DONE
21. Con rod bearings (Paragon)------DONE
22. front tow hook (no real reason, just thought it looked cool!!) (Paragon)-----DONE
23. Mafterburner tuner-----needs doing
17. MAF trap (LR)
#49
finally into the computer and tuning stage but am having trouble getting a consistant reading from the Innovate Air / FUel gauge. It seems to jump around in random positions, not at all related to actual driving situations. Any ideas??
#59
If you give JustinL your email he can put you on the list to be notified of our next PCA event, should be early July.
Send me a PM with your cell number and I'll send you a text next time we do a coffee, usually they're on a Friday evening at the Tims/United Cycle on Gateway Blvd.
