WTB: OEM tranny cooler for lsd trans
Looking to add this.
Anyone have a complete setup with cooler ring, pump, drive gears, etc, etc for sale?
Is this what you are looking for, saw this post a little while back.
https://rennlist.com/forums/944-turb...plete-kit.html
He doesn't have the drive gear needed for an lsd trans. I've pm'd him about it offering to buy what he has for now and didn't get a response...
Basic Sponsor
First of three step completed. Redoing the gear took about 30 minutes to drill out the holes and cut out the inside of the open diff oil pump gear. The large hole are not used for mounting, so the alignment of the gear was done to get metal around the four small holes that are used for mounting. The drills used were
23/64 for the small hole and 9/16 for the large holes. The inside material was cut back and then filed to final alignment. The metal on the oil pump gear is very soft. The picture shows the LSD gear mounted to the open diff gear after it was modifiied.
Next step is to pull the back cover on the trany and drill the return oil line for the oil cooler loop,
