Head Light washer system install... Anyone ever done this?
I'm installing the head light washer jets in-place of the delete plugs. I just simply prefer the look! What all will I Need? I've purchased the jets,and the pump. I know I will need Lines,and I know the wiring is there for the pump,as I've installed a brand new engine bay wiring harness in this car. My real question is... do I need to get a relay or different steering column controls?
Thanx in advance
Brian
Thanx in advance
Brian
I have them on my car and I hardly ever use them.
I think the fluid reservoir is different. The one on my car is huge. They are activated by pushing foreward on the wiper stalk. Parts suppliers list a different part for cars that have this feature.
I've collected all the factory parts to do add them. You'll need the relay, the steering column assembly switches, the jets, hoses, hose clamps, and there is a Y-valve up front that also serves as a check valve so the fluid doesn't trickle out the jets when not in use.
Thank You for the info. Thats what I was thinking I would need,but was not certain.
