K28 or K27?
Is the Tial F38 a dualport wastegate? On their site it doesnt mention it. What is or how does a dual port wastegate work? Compared to what im assuming are single port wastegates?
you set up a little air regulator feeding into the opposite side of the actuator where the spring is the more air you supply with the reg the more the waste gate effectively increases pressure
yeh its worth it I don't think its much of an expense and the control is realy good with it .. with out it you are playing around with electronic boost controls and pneumatic trickery
